#26 19-03-2022 15:03:56
Mirza
Registrovaný: 16-03-2022
Re: Fronius Variostar 247-motorek podavače píská
Thank you very much, kind man!
  I assume that there is no schematics available for this PCB, as I have couple of blown SMD components, even the high resolution picture of PCB would be helpful.
vastrap napsal(a):
Toto je doska MR25, starsia, ktora sa uz nepouziva, nahradza sa doskou MR26. Tam je mosfet P24NF10.
#27 21-03-2022 19:49:54
vastrap
Registrovaný: 24-11-2012
Of course there is no schematics. Try to take a picture of the demaged parts please.
#28 22-03-2022 08:18:47
JaroslavPavel
Registrovaný: 03-07-2017
Pane, jestli budete chtít, tak Vám to schéma udělám .
#29 24-03-2022 02:00:57
Mirza
#30 27-03-2022 21:42:40
vastrap
Fotka http://www.svarforum.cz/forum/uploads/thumbs/4343_rezisory.jpg
MR26. Obvody su podobne ako MR25. Zhorete odpory su 22R  4ks. Na dalsej fotke tranzistory. Su tam pouzite bud BC 817-25 alebo BC 807-25, treba to vystopovat podla zapojenia.
#31 27-03-2022 21:44:09
vastrap
http://www.svarforum.cz/forum/uploads/thumbs/4343_tranzistor.jpg
#32 29-03-2022 01:55:17
Mirza
Yes, the MR25 & MR26 are quite similar.
Thank you, that's the data I needed.
Thank you all, you're very kind and polite people.
#33 Včera 23:34:40
mato3
Registrovaný: 25-07-2009
Ahojte
ja mam zase taky problem s doskou MR26A ze ihned po zapnuti napajania (dosky) sa zopne elektromagneticky ventil plynu.
Na pinoch 3 a 4 (konektor X1) sa ihned po zapnuti dosky objavy napetie.
Vedeli by ste poradit cim to moze byt ?
to vastrap podla toho co si tu pisal vyzera ze sa v tychto doskach celkom vyznas, vedel by si poradit ?
mozno prerazilo nejaky vykonovy tranzistok , neviem lebo zvaracku som uz takto s tymto problemom kupil smile
MIG/MAG- FRO Saldatura Practic 254
MMA- Uta 200 I
