#1 12-10-2020 05:38:47
MosleyCale
Registrovaný: 12-10-2020
proteco fusion mig-175
Other special uses of a vacuum cleaner you may not know yet
Vacuum cleaner is known as a supportive appliance to clean your home by removing most of the dust and dirt. But have you heard of other special uses of a vacuum cleaner? Let’s review in this article and apply for your own machine at home.
1. Remove pet hairs
Removing pet hairs on floors or carpets is a familiar use to many people. However, not many people notice using vacuum cleaners to clean pet hairs at pet’s bedding, their toys or other household surfaces that they usually contact.
Washing the clothes, pillowcases or blankets with too much embedded pet hairs may cause leakage, blockages, and break the pumping system of the washing machine. They may even stick to other clothing and could not be washed.
Every corner and surface that your pets usually contact with should be cleaned frequently.
2. Kill insects
Vacuum cleaner may kill up to 96% of vermin, both mature and larval. Moreover, you can catch spiders or mosquitoes at ceiling corners with a vacuum cleaner. During the cleaning process, to avoid the spider web sticking into the vacuum head, attach a clean cloth to the brush head to remove the spider web efficiently.
3. Kill bacteria, bugs, mold:
Most of the best vacuum cleaners in the world now are equipped with standard or HEPA filters. Thanks to the advance of technology, these filters help to remove up to 99% of bacteria, dust and mold – which usually cause disease relating to respiratory, asthma, especially danger to allergy sufferers and kids.
https://i.imgur.com/K5lLAyj.jpg
4. Air freshener:
With Cyclonic separation technology, a vacuum cleaner would clean up to 99% dust and bacteria, using a method of removing particulates from an air stream through vortex separation. Thus, vacuum cleaners help to refresh the air for your home.
Besides, some of the Best Rated Vacuum Cleaners now equipped with the latest technology focus on removing bad smells and cigarette smell in the air.
5. Absorb moisture, dry the surface
Nano or HEPA filters in vacuum cleaners have the ability to absorb moisture and dry air. This is extremely helpful and practical in the rainy and high moisture season, to reduce humidity and mold in your house.
6. Blow dust
The vacuum cleaner now not only gap dirt and dust, but also have a “blow” function. It is really useful to collect rubbish like leaves, fallen flowers, saving much time and effort instead of sweeping as before.
https://i.imgur.com/Ok6xJMy.jpg
7. Renew the sofa, pillows and carpets with baking soda
An alternative option to save the cost of getting a cleaning service provider to wash sofa, carpets and beds is to use your vacuum cleaner and baking soda. After sprinkling baking soda on the couch, pillow, carpet or foot mats, then use a warm sponge to spread on the cleaning surface. Leave it for one hour, then vacuuming the baking soda and dirt, dust, smell out of the surface.
8. Clean other household appliances.
Not only the surface at home need to be cleaned, but also other household appliances. You can use vacuum cleaner to clean dust, dirt left behind on electric wires, refrigerators, fans, air conditioners. For those who love books, vacuum cleaners would clean dust well, keep your books last longer.
In conclusion, owning best vacuum cleaners on the market would help to increase your quality of life by bringing the fresh air, and removing most of the allergen factors, dirt, and dust and keep your home clean and safe. Try to maximize the usage of your vacuum cleaner and you will be surprised with what it can do for you.
Editoval MosleyCale (05-01-2024 09:41:17)
#2 12-10-2020 19:17:11
Re: proteco fusion mig-175
