#1 13-07-2019 22:27:57
Maxipes
Registrovaný: 13-07-2019
Ahoj,je to dobrá kukla ?Nebo poradíte lepší do 1500 Kč ?
kukla Proteco P800E   https://www.prijemny-dum.cz/proteco-kuk … gLHiPD_BwE
Editoval Maxipes (13-07-2019 22:35:24)
#2 13-07-2019 22:49:51
Re: Ahoj,je to dobrá kukla ?Nebo poradíte lepší do 1500 Kč ?
cim lepsia kukla, tym viac jedniciek - plati rovnake pravidlo, ako pri adidase - cim viac pruzkov, ..... idealne, ked sa s nou mozes pomazlit, vytunit, vylepsit, vytlacit na 3D tlaciarni nejake stlpiky - proste k nej ziskas nejaky citovy vztah a uz nebudes chciet inu ...........
http://www.svarforum.cz/forum/viewtopic … 95#p142795
pripadne nieco pre "sikme" ocko - cinan ti da styri jednicky 1/1/1/1 aj na flasku od piva, kua este aj zabalene v americkej zastave, ze aj chuck norris by zavidel.....
€ 51,77  40%OFF | Welding Mask Best Optical Quality 1/1/1/1 Big View 100*73MM 3.94*2.87" Respirator Safety Hat Compatible CE Solar Welding Helmet
https://s.click.aliexpress.com/e/cXAJGOwy
€ 50,29  40%OFF | Welding Mask Best Optical Quality 1/1/1/1 Big View 3.94x2.56" 100x65mm Widest Shade Range DIN(3)4-13 CE Solar Welding Helmet
https://s.click.aliexpress.com/e/5FoMu8C
€ 46,28  30%OFF | Welding Mask Top Class 1/1/1/1 View 100*65mm(3.94*2.56") Shade 3(4)/4-8/9-13 Solar 4 Sensors Carbon Fiber Welding Helmet EN379
https://s.click.aliexpress.com/e/c3LOJkMo
€ 19,40  26%OFF | Aldismala Welding Helmet Best Optical Quality 1/1/1/1 Big View Size 96x48mm Welding Mask Head-mounted automatic Adjustable mask
https://s.click.aliexpress.com/e/c0fgeCOy
https://www.youtube.com/watch?v=k3DQ0-u_B4A
https://www.youtube.com/watch?v=EfEXEcO97Hs
https://www.youtube.com/watch?v=0ULwHF74_1w
https://www.youtube.com/watch?v=c1FUBkzf2fc
Ps: chuck udajne zvladne PF-ku aj na padaka celulozovou elektrodou .....
Editoval rcp (13-07-2019 23:07:35)
#3 21-07-2019 21:28:34
misiacik36
Registrovaný: 01-03-2018
kedysi som tu riešil problém s výmenou baterie do proteco p-600 a kedze sa to nepodarilo, tak som kupil novu, lacnu. na domace "lepenie". skutočne prilezitostne s prudom max 120A elektrodou... zobral som solution ts-800 za 63e. teraz som pozeral a uz maju inu kazetu, tu "farebnu". je to moja druhá kukla, mozem porovnat len s proteco a je to nebo od zeme... pri proteco p-600 ma oci boleli, rezali, mal som nablikane neskutocne. teraz uplne v pohode, nic necitim. sice som neporadil, lebo teraz uz predavaju s novou kazetou a ta neviem aka je... v cine samotna kazeta na tu moju kuklu stoji viac ako 100e, teda netusim ako predavaju kuklu lacnejsie ako kazeta v cine...
#4 22-07-2019 04:30:50
Carls
Registrovaný: 16-03-2019
Připlať pár kaček a kup https://www.svarecky-obchod.cz/prisluse … -kwx73.htm
Budeš spokojený proteco mi leží ve skříni a už ho víc nechci z kwx73  mě nebolí oči ani když svářím celý odpoledne  Je to dobra kukla pro hobby
#5 13-10-2019 18:26:17
pavelak
Registrovaný: 12-10-2019
#6 14-10-2019 03:53:57
Carls
Za mne si raději připlatit a koupit http://www.svarujeme.com/svarovaci-kukl … wax-kwx73/
Taky sem si ji kopil proteco, kdysi a válí se mi doma  pak jsem koupil KWX73 a sem opravdu spokojený už mě neboleli oči když sem svařoval
Možná sem chytil od proteca aušus nevím ale nějak nešla nastavit buď sem neviděl nebo boleli oči
#7 16-12-2019 20:43:27
Pade
Registrovaný: 16-12-2019
Chlapi, prosim nazor, vybiram mezi zminovanou KWX73 a GYS Ergotech (https://www.metaweld.cz/samostmivaci-ku … ys%20black) s papirove lepsimi parametry a vetsim pruhledem. Mate zkusenost? Diky
#8 02-02-2020 10:20:57
Pade, co jste nakonec koupil? V práci teď mám na stehování taky tu KWX 73 a velká spokojenost. Za ty peníze luxus. GYS kukly nevím, v bývalé práci měl jeden chlápek takovou tu stříbrnou, vypadala hodně dobře, ale ta už stojí kolem 3500,- kč.
