#1 20-03-2009 02:31:43
Gasserman
Registrovaný: 19-01-2009
100% svařitelný hliníkové trubky
Pánové prosím poradte kdo tu dělá se 100% ověřenýma svřitelnýma hliníkovýma trubkama
potřebuju průměry
- 50 na 1 mm
-15x0,5 mm
plech 1 mm a 0.5 mm
jaké je přesné číslo a kde mají?
Dík moc.
#2 22-03-2009 16:19:18
780622
Místo: dechtice sr
Registrovaný: 05-10-2008
Re: 100% svařitelný hliníkové trubky
ahoj gasserman, skus 6061
6061 Aluminum is, by most any measure, the most commonly used aluminum alloy. It is specified in most any application due to its strength, heat treatability, comparatively easy machining, and weldability. If that were not enough, it is also capable of being anodized, adding a layer of protection for finished parts.
(available in Angle, Channel, I-Beam, Pipe, Plate, Rectangle, Round, Sheet, Square, Tube)
The main alloy ingredients of 6061 aluminum are magnesium and silicon.
6061-T6 Aluminum
Ultimate Tensile Strength, psi     45,000
Yield Strength, psi     40,000
Brinell Hardness     95
Rockwell Hardness     B60
Chemistry     Aluminum (Al)     95.8 - 98.6%
Chromium (Cr)     0.04 - 0.35%
Copper (Cu)     0.15 - 0.40%
Iron (Fe)     0.70%
Magnesium (Mg)     0.8 - 1.2%
Manganese (Mn)     0.15% max
Silicon (Si)     0.4 - 0.8%
Zinc (Zn)     0.25%
EWT (Ingsteel)
#3 23-03-2009 13:45:45
780622 napsal(a):
6061 Aluminum is, by most any measure, the most commonly used aluminum alloy. It is specified in most any application due to its strength, heat treatability, comparatively easy machining, and weldability. If that were not enough, it is also capable of being anodized, adding a layer of protection for finished parts.....
To je široce používaný druh Al slitiny s dobrou svařiteností jak MIG, tak TIG. Berte však v úvahu, že po provedení sváru se sníží pevnost v tahu až o 80%.
#4 23-03-2009 15:08:06
780622
Místo: dechtice sr
to frank: ja som len pisal dobre zvaritelny druh Al zliatiny. tu pevnost v tahu som neskumal. aka je lepsia Al zliatina ktora tento problem, popr. nejake ine problemy nema? tiez ma to zaujima - naj Al zliatina na zvaranie...
EWT (Ingsteel)
#5 23-03-2009 15:45:09
780622 napsal(a):
Těžko napsat která je nejlepší svařitelná slitina Al. Obecně vzato, slitiny obsahující příliš velké procento legur, jako Cu, Zn ap. jsou obtížně svařitelné.
Přehled nejvíce používaných Al materiálů je zde, ale jak je to se svařitelností jednotlivých druhů, to si musíte vyhledat v patřičných materiálových vlastnostech toho kterého. smile
http://www.steelforge.com/aluminumalloy … DQodr0djjQ
